Knowledge Base Article
Is there a known problem with IBIS model generation with the Model Selector option enabled when using bi-directional pins with Parallel OCT in Intel® Stratix® 10 devices?
Description
Due to a known problem in Intel® Quartus® Prime Pro Edition Software version 22.1 and earlier, you may see that the IBIS models generated for bi-directional pins when using Intel® Stratix® 10 devices are missing parallel termination options. This is only seen if you have the Model Selector option enabled under Settings -> EDA Tool Settings -> Board-Level signal integrity analysis
Resolution
To work around this, generate the IBIS models with the Model Selector option disabled.
Updated 1 month ago
