Knowledge Base Article
Is there a known issue with the pre-emphasis settings in Cyclone V LVDS IBIS models generated by the Quartus Prime software?
Description
Yes, due to an issue with generation of Cyclone® V IBIS models in the Quartus® Prime software versions 16.0 and earlier, you will see swapped model behavior for the LVDS pre-emphasis setting.
For pre-emphasis ENABLED - _p1:  simulation result shows pre-emphasis disabled.
For pre-emphasis DISABLED- _p0:  simulation result shows pre-emphasis enabled.
Resolution
To work around this issue, manually change the pre-emphasis setting when generating the IBIS model in the affected versions of the Quartus Prime software.
This issue is fixed in Quartus Prime software versions 16.1 and later.
Updated 2 months ago
Version 2.0
