Knowledge Base Article
Is the PWRMGT_ALERT signal generated by Intel® Stratix® 10 devices active high or active low?
Description
When the PWRMGT_ALERT signal is enabled in Intel® Stratix® 10 devices operating in PMBus slave mode, by default the signal will be weakly pulled high and when issuing an ALERT, the Intel Stratix 10 device will pull PWRMGT_ALERT low. Hence this signal can be considered active Low.
Resolution
This information is included starting from Document Version 2020.01.23  of the Intel® Stratix® 10 Power Management User Guide
Updated 3 months ago
Version 2.0
