Knowledge Base Article
Is the genlock feature supported in VIP suite CVO II and CVI II IPs?
Description
No, the Genlock feature is not supported in Clocked Video Output (CVO) II IP and Clocked Video Input (CVI) II IP. The "Accept synchronization outputs" option has been removed from these IPs starting Quartus® Prime software version 16.0. Do not use this feature in v15.1.
Resolution
The (original) CVO IP and CVI IPs can still be used to synchronize the output.
Updated 1 month ago
