Knowledge Base Article
Is it possible to override the default module parameters for an  IEEE 1735 encrypted IP in the Quartus® Prime Pro Edition Software?
Description
Yes, when instantiating an IEEE 1735 encrypted IP, different parameters can be passed to the module in the same manner as a non-encrypted module.
Resolution
The encryption key is the same for Verilog HDL and VHDL. You can pass parameters to the instantiation of an encrypted module using the same method as a non-encrypted module.
Updated 29 days ago
Version 2.0
