Knowledge Base Article
IP Search Path option functions incorrectly in the SOPC Builder
Description
If you add IP search paths to your design for the first time using the IP Search Path Options dialog box in the SOPC Builder, the search path might not be added when you select the search path, click Add and then click Finish.
The IP search path appears in the SOPC Builder if you add the search path in Qsys.
Resolution
If the search path is not added in the SOPC Builder, repeat the addition step by selecting the search path, click Add and then click Finish. Alternatively, delete the user_componenets.ipx file and then add the search path in the SOPC Builder.
Updated 1 month ago
Version 2.0
