Knowledge Base Article
IP Compiler for PCI Express Stratix IV GX Reset Controller Does Not Enter Recovery Immediately if Reference Clock Constraints are Not Met
Description
The reset controller logic for the IP Compiler for PCI Express
hard IP implementation with internal reset modules on Stratix IV
GX devices does not monitor the pll_locked state after
the busy_altgxb_reconfig signal is deasserted. As a
result, you may observe link instability before the IP Compiler
for PCI Express goes into link recovery following loss of PLL lock.
This issue affects all IP Compiler for PCI Express hard IP implementations with internal reset modules on Stratix IV GX devices.
Resolution
To avoid this issue, ensure that your IP Compiler for PCI Express transceiver reference clock meets the following requirements:
- The reference clock must be a free running clock that is valid after the device powers up.
- The reference clock must remain stable during normal operation, soft reset, hot reset, powerdown, Link Down state, and other expected situations.
This issue will not be fixed in a future version of the IP Compiler for PCI Express. Correct operation requires that the design follow the reference clock constraints described in the Workaround section.
