Knowledge Base Article
IP Compiler for PCI Express r2c_err0 Signal Toggles Unexpectedly
Description
The IP Compiler for PCI Express r2c_err0 signal
should be asserted to indicate an uncorrectable ECC error on virtual
channel 0. However, this signal toggles frequently when no error
is present, and toggles even if the ECC encoder and decoder are
disabled.
This issue affects all IP Compiler for PCI Express HIP variations that target a Cyclone IV device.
Resolution
To work around this issue, ensure that your design ignores
the IP Compiler for PCI Express r2c_err0 signal output
from the affected variations.
This issue is fixed in version 11.1 of the IP Compiler for PCI Express.
Updated 3 months ago
