Knowledge Base Article
Internal Exception Error During Elaboration with NCSim
Description
This problem affects designs that contain a Reed-Solomon II decoder. when you elaborate your design in Cadence NcSim, you may receive a elaboration error.
Resolution
To work around this problem, install and run the Cadence INCISIV12.20-s022 or later release from the Cadence website.
This problem is scheduled to be fixed in a future version of the RS II IP core.
Updated 1 month ago
