Knowledge Base Article
Internal Error:Sub-system: PGMIO, File: /quartus/pgm/pgmio/pgmio_jam.cpp
Description
Due to a problem in the Programmer in the Quartus® Prime Pro Edition Software version 19.2, you may see this internal error when generating the JAM file for the erase operation.
Resolution
To work around this problem, use an input JTAG Indirect Configuration File (.jic) when generating the Jam™ Standard Test and Programming Language (STAPL) Format File (.jam) for erase Active Serial Flash operations.
This internal error was fixed in version 20.1 of the Quartus® Prime Pro Edition Software.
Updated 2 months ago
