Knowledge Base Article
Internal Error when using memory interface toolkit application in QII V12.1
Description
You may see internal error when you try to use EMIF toolkit in QII V12.1 when you try to open "read data valid window"Resolution
This is a bug issue and will be fixed in QII V12.1SP1Updated 3 months ago
