Knowledge Base Article
Internal Error When Double-Clicking on a Large Objdump File
Description
On Windows when opening a large objdump file in the Nios II IDE, you might get the following error message:
Unable to create this part due to an internal error. Reason for the failure: Editor could not be initialized.
Resolution
Adjust the Windows launch arguments for the Nios II IDE editor. Perform the following steps:
  1. On the Windows Start menu, browse to the Nios II EDS program icon, right-click it, then click Properties. The Windows Properties dialog box appears.
  2. In the Target field, append "vmargs -Xmx1024m" to the end of the path to the Nios II IDE executable. For example:
C:\altera\72\nios2eds\bin\eclipse\nios2-ide.exe -vmargs -Xmx1024m
Updated 1 month ago
Version 2.0
