Knowledge Base Article
Internal Error: Sub_system:FITCC, File:/quartus/fitter/fitcc/fitcc_expert.cpp, line: 1146
Description
Due to a problem in Quartus® II software version 10.1 SP1 and earlier, you may see this error when compiling designs targeting an Arria® II GX device.  This problem occurs when you have the global assignment PHYSICAL_SYNTHESIS_LOG_FILE set to ON in your Quartus II Settings File (.qsf).
To work around this problem, edit your .qsf and either remove this assignment or set it to OFF.
This problem is fixed beginning with the Quartus II software version 11.0.
Updated 3 months ago
Version 2.0
