Knowledge Base Article
Internal Error: Sub-system: WSC, File: /quartus/neto/wsc/wsc_port_data.cpp, Line: 293
Description
Due to a problem in the Quartus® II software versions 10.0 and later, this error message may be generated while running the EDA Netlist Writer if the option to maintain hierarchy in the output gate-level simulation netlist has been enabled.
To avoid this error, turn off the option by performing the following steps:
- Open the Settings dialog box by selecting Settings... on the Assignments menu
- Display the Simulation settings page by selecting Simulation under EDA Tool Settings
- Open the More EDA Netlist Writer Settings dialog box by clicking the More EDA Netlist Writer Settings... button
- Select the option Maintain hierarchy and change the setting to Off
This problem is scheduled to be fixed in a future version of the Quartus II software.
Updated 1 month ago
