Knowledge Base Article
Internal Error: Sub-system: VRFX, File: /quartus/synth/vrfx/verific/vhdl/vhdltreenode.cpp, Line: 1103
Description
Due to a problem in the Intel® Quartus® Prime Standard Edition Software version 18.1 and earlier, you may see this internal error when you use a nested generate loop in the design.
Resolution
To work around this problem, do not use the nested generate loop or use the Intel® Quartus® Prime Pro Edition Software.
Updated 1 month ago
Version 2.0
