Knowledge Base Article
Internal Error: Sub-system: VRFX, File: /quartus/synth/vrfx/verific/verilog/veriname_elab.cpp, Line: 836
Description
Due to a problem in the Quartus® Prime Standard Edition Software version 17.1 and earlier, you may see this internal error during synthesis.
read to RAM wasn't mapped to a specific read port
Resolution
To work around this problem, prevent RAM conversion from an unpacked array through the Quartus Setting File(QSF).
    set_global_assignment -name AUTO_RAM_RECOGNITION OFF -entity <module_name>
    or
    set_global_assignment -name AUTO_RAM_RECOGNITION OFF -to <instance_path>
Updated 2 months ago
Version 2.0
