Knowledge Base Article
Internal Error: Sub-system: VRFX, File: /quartus/synth/vrfx/verific/verilog/veriname.cpp, Line: 1211 _inferred_type_name
Description
Due to a problem in the Intel® Quartus® Prime Standard Edition Software, you may see this problem when running the Analysis & Elaboration compilation phase.
Resolution
To work around this problem, assign cgate_out.len[10:0] to a temp wire and use that temp wire in your module instantiation, this will fix the IE.
Updated 2 months ago
