Knowledge Base Article
Internal Error: Sub-system: VPR20KMAIN, File: /quartus/fitter/vpr20k/vpr_common/route_node_reservations.c, Line: 327
Description
Due to a problem in the Quartus® II software version 12.0 and later, you may see this internal error during fitting. The problem occurs when you have set theallow multiple personas option on unsupported device families.Resolution
To avoid this problem, do not set the allow multiple personas option when compiling for an unsupported device family.
Updated 1 month ago
