Knowledge Base Article
Internal Error: Sub-system: VPR20KMAIN, File: /quartus/fitter/vpr20k/quartus_interface/qi_common/vpr_qi_timing_analysis_direct_api.cpp, Line: 1084
Description
Due to a problem in the Quartus® II software version 12.0 SP2, you may see this internal error if your design contains an Avalon® Memory-Mapped interface.Resolution
To work around this problem, use a different seed as the problem is seed dependent.
This problem is fixed beginning with the Quartus II software version 12.1.
Updated 1 month ago
