Knowledge Base Article
Internal Error: Sub-system: U2B, File: /quartus/db/u2b/u2b_av_m10k_param.cpp, Line: 2021
Description
Due to a problem in the Quartus® II software version 13.0sp1dp6 or earlier, you may see this internal error when you compile an Arria® V or Cyclone® V design that contains an FFT IP.
Resolution
This problem is fixed beginning with the Quartus II software version 13.1
Updated 2 months ago
Version 2.0
