Knowledge Base Article
Internal Error: Sub-system: TILEIP, File: /quartus/db/tileip/tileip_writer.cpp, Line:3784
Description
The F-Tile Low Latency 50G Ethernet FPGA Soft-IP will fail to compile due to the use of a "vsr-mode=VSR_MODE_LOW_LOSS" constraint, causing a compilation error in the Quartus® Prime Pro Edition Software version 23.2.
Below are the error snapshots.
Resolution
To workaround this problem, change the alt_e50_f_hw.qsf setting as vsr_mode=VSR_MODE_LOW_LOSS in the Quartus® Prime Pro Edition Software version 23.2.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
