Knowledge Base Article
Internal Error: Sub-system: THR, File: /quartus/ccl/thr/thr_thread.c, Line: 266
Description
Due to the limitation of memory resource availablility for 32-bit operating systems, you may see this internal error during compilation when using the 32-bit version of the Quartus® II software.
Resolution
To avoid this error, use the 64-bit version of the Quartus II software on a computer with sufficient memory. Refer to Documentation: Release Notes for links to the Quartus II Software and Device Support Release Notes (PDF) for the memory requirements of Altera devices. For older version of the Quartus II software, refer to the Archive section on that webpage.
Updated 3 months ago
