Knowledge Base Article
Internal Error: Sub-system: SUT, File: /quartus/neto/sut/sut_delay_util_helper.cpp, Line: 4158
Description
This error may be seen in the Quartus® II software versions 10.0 and 10.0 SP1 if you target a Cyclone® IV device and you enable the EDA Netlist Writer to generate a simulation netlist. This error is triggered when the Standard Delay Format Output file (.sdo) is generated.
To work around this problem, disable the EDA Netlist Writer from generating the (.sdo) file by following these steps:
- On the Assignments menu, select Settings.
- In the Setting dialog box, expand the EDA Tool Settings category.
- Click Simulation.
- Click More EDA Netlist Writer Settings.
- Select the option Generate netlist for functional simulation only.
- Change the setting to On.
Resolution
This problem is fixed beginning with the Intel® Quartus® II software version 10.1.
Updated 2 months ago
