Knowledge Base Article
Internal Error: Sub-system: SSYN, File: /quartus/synth/ssyn/ssyn_env.cpp, Line: 304
Description
Due to a problem in the Quartus® II software version 12.0 and later, you may see the following internal error during synthesis:
m_atom_node_vector[atom_node->get_id()] == 0Resolution
To work around this issue, turn off physical synthesis options by following the steps below:
- Select Settings from Quartus II Assignments menu
- Click on Compilation Process Settings in the Category window
- Turn off the physical synthesis options under Physical Synthesis Optimizations
This problem is scheduled to be fixed in a future release of the Quartus II software.
Updated 2 months ago
