Knowledge Base Article
Internal Error: Sub-system: SDR, File: /quartus/sld/sdr/sdr_tx_trigger.cpp, Line: 6408
Description
Due to a problem in the Quartus® II software version 10.1, the SignalTap II Logic Analyzer may crash when saving the file after adding an Edge & Level Detector for an Advanced mode trigger condition.
This problem is fixed beginning with the Quartus II software version 11.0. To work around this problem in version 10.1, edit the Advanced Triggers in version 9.1 SP2 or earlier.
Updated 3 months ago
Version 2.0
