Knowledge Base Article
Internal Error: Sub-system: SDR, File: /quartus/sld/sdr/sdr_tx_signal_nodes_gen2.cpp, Line: 781 alias != NULL && *alias != '\0'
Description
Due to a problem in the Quartus® II software version 13.0 SP1 and earlier, you may see this internal error in the SignalTap™ II Logic Analyzer when deleting an alias for a node.
Resolution
To work around this problem, perform the following steps:
- Close the SignalTap II Logic Analyzer
- Open the SignalTap II file (.stp) in a text editor and delete all the lines matching
.alias= “<name>” - Reopen the SignalTap II Logic Analyzer
Updated 1 month ago
