Knowledge Base Article
Internal Error: Sub-system: RCOMP, File: /quartus/comp/rcomp/rcomp_mgr_impl.cpp, Line: 320
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 22.1 or earlier, you may see this internal error when you try to compile the design. This is caused by the Quartus® Prime Pro Edition Software trying to reach the Cloud Notification Center that has been marked EOL (End of Life).
Resolution
To avoid this problem in the Quartus® Prime Pro Edition Software, follow the steps below:
1. Go to Tools, Options, Internet Connectivity, and turn off the Notification Center feature.
2. In your quartus2.ini fileremove any assignment that will try to reach the Notification Center
The quartus2.ini file is located at:
For Windows OS, go to C:/user/<username>/
For Linux OS, cd to home/<user>/.altera.quartus
Example of cloud related setting that need to be removed:
CLOUD_SEND_END_FLOW_NOTIFICATIONS = on
CLOUD_SEND_REPORTS = on
CLOUD_SERVER = https://fpgacloud.intel.com
CLOUD_TOKEN = <secret>
CLOUD_USERNAME = <username>
3. In your .qsf file, remove any assignments that are tagged with dse_intenal. Example:
             set_global_assignment -name CLOUD_NOTIFY_GROUP_ID 23485 -tag dse_internal
       set_global_assignment -name CLOUD_NOTIFY_ENABLE ON -tag dse_internal
This problem is fixed beginning with the Quartus® Prime Pro Edition Software version 22.2.
Updated 17 days ago
Version 2.0
