Knowledge Base Article
Internal Error: Sub-system: QTK, File: /quartus/db/qtk/qtk_io_option_mover.cpp, Line: 291
Description
Due to a problem in the Quartus® II software version 12.0 SP2 and earlier, you may see this error when exporting post-synthesis partition.
Resolution
To work around this problem, disable the SignalTap™ II Logic Analyzer in your design before compiling your design and then export the design partition.
This problem is fixed beginning with the Quartus II software version 12.1.
Updated 1 month ago
Version 2.0
