Knowledge Base Article
Internal Error: Sub-system: QHD, File: /quartus/comp/qhd/qhd_design.cpp, Line: 731
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 24.1 and earlier, you might see the error above when running the command execute_flow -compile with the executable quartus_sh.
Resolution
To work around this problem, use one of the following steps:
  • Running the compilation through the GUI mode
or
  • Using the command quartus_sh --flow <project_name>.qpf
This problem is fixed starting with the Quartus® Prime Pro Edition Software version 24.2.
Updated 1 month ago
Version 2.0
