Knowledge Base Article
Internal Error: Sub-system: PTI, File: /quartus/tsm/pti/pti_tdb_builder.cpp, Line: 1357
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 20.4 and earlier, you might see this internal error at the Route stage.
Resolution
To work around this problem, assign a proper location to the port listed in the Warning message (21833) before running Route.
This problem is fixed beginning with the Intel® Quartus® Prime Pro Edition Software version 21.3.
Updated 1 month ago
Version 2.0
