Knowledge Base Article
Internal Error: Sub-system: PGMIO, File: /quartus/pgm/pgmio/pgmio_jam.cpp, Line: 3270
Description
You might see this error in the Intel® Quartus® Prime Pro Edition Software version 22.1 and earlier, when creating a JAM/JBC programming file.
This is seen when an Active Serial flash is attached to a Cyclone® V/Stratix® V/Arria® V device in the JTAG chain without any flash programming file assigned.
Resolution
To work around this problem, remove the Active Serial flash from the Cyclone® V/Stratix® V/Arria® V device in the JTAG chain and then proceed to the JAM/JBC file generation.
This problem is fixed starting with the Intel® Quartus® Prime Pro/Standard Edition Software version 22.2
Updated 1 month ago
