Knowledge Base Article
Internal Error: Sub-system: PGMIO, File: /quartus/pgm/pgmio/pgmio_devices.cpp, Line: 7667 Cannot locate the SFL sof file
Description
Attempting to program an Arria V or Stratix V device with JTAG Indirect Configuration File (.jic) might fail with an error similar to the following:
Line: 7667
Can not locate the SFL sof file
Resolution
Manually instantiate and compile a Serial Flash Loader (SFL) megafunction by following the instructions in Instantiating SFL Megafunction in the Quartus II Software in AN 370: Using the Serial FlashLoader with the Quartus II Software on the Altera website. Then program the device.
Updated 27 days ago
