Knowledge Base Article
Internal Error: Sub-system: MEM, File: /quartus/ccl/mem/mem_segment.cpp, Line: 735
Description
Due to a problem in the Quartus® II software versions 11.0 SP1 and earlier, you may see this error when compiling your design if the Timing-Driven Synthesis option is turned on.
Resolution
To work around this problem, turn off the Timing-Driven Synthesis option on the Analysis & Synthesis Settings page of the Settings dialog box.
This problem is fixed beginning with the Quartus II software version 12.0.
Updated 2 months ago
Version 2.0
