Knowledge Base Article
Internal Error: Sub-system: HSSI, File: /quartus/periph/hssi/hssi_module_av.cpp, Line: 6805
Description
Due to a problem in the Quartus® II software version 13.1 and earlier, you may see this internal error if your design targets an Arria® V ES or Cyclone® V ES device and have Configuration via Protocol (CvP) enabled.
Resolution
To work around this problem, either target a non-ES device or disable the option for CvP.
This problem is scheduled to be fixed in a future release of the Quartus II software.
Updated 1 month ago
Version 2.0
