Knowledge Base Article
Internal Error: Sub-system: HPS, File: /quartus/periph/hps/hps_module_gen6.cpp, Line: 566
Description
Due to a problem in the Intel® Quartus® Prime Standard Edition Software version 17.1 Update 2 or later, you may see this internal error when the location assignment for the HPS IP had been removed from the .qip files.
pad_index <= m_num_dedicated_io && pad_index > 0
Resolution
To work around the problem, regenerate the HPS IP. The location assignment is auto generated to the .qip file.
Updated 1 month ago
Version 2.0
