Knowledge Base Article
Internal Error: Sub-system: HDB, File: /quartus/db/hdb/hdb_inst_name.cpp, Line: 703
Description
Due to a problem in the Quartus® Prime Standard Edition software version 17.0 and earlier, you may see this internal error when using the SignalTap Logic Analyzer. This error occurs when an instance name contains a space and the trigger in/out functionality is used.
Resolution
To work around this problem, do not use a space in the instance name.
This problem is scheduled to be fixed in a future release of the Quartus Prime Standard Edition software.
Updated 1 month ago
Version 2.0
