Knowledge Base Article
Internal Error: Sub-system: FYGR, File: /quartus/fitter/fygr/fygr_cdr_op.cpp, Line: 2875
Description
Due to a problem in the Quartus® Prime Standard Edition Software version 19.1 or earlier, you may see this internal error when the I/O standard is assigned to LVDS, but this pin is not connected to the LVDS IP. This problem only occurs in MAX® V CPLD devices.
Resolution
To work around the problem, change the I/O standard from LVDS to another type of I/O standard if the pins are not connected to the LVDS IP.
Updated 2 months ago
