Knowledge Base Article
Internal Error: Sub-system: FSV, File: /quartus/fitter/fsv/fsv_module.cpp, Line: 2408
Description
Due to a problem in the Quartus® II software version 12.0 and later, you may see this error if you have assigned an input HSSI pin with no fan-out.
Resolution
To work around this problem, remove the location assignment for the HSSI pin with no fan-out.
This problem is fixed beginning with the Quartus II software version 12.1.
Updated 1 month ago
