Knowledge Base Article
Internal Error: Sub-system: EMITT, File: /quartus/sld/emitt/emitt_hardware_driver_impl.cpp, Line: 1019
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition software version 18.1 Update 2 and earlier, you may see this error when using EMIF Debug Toolkit.
Resolution
This error is caused by the lack of a refence clock, please make sure the refence clock frequency is correct and present before the EMIF Debug toolkit is running.
This problem is fixed in the Intel® Quartus® Prime Pro Edition software version 20.1.
Updated 3 months ago
Version 2.0
