Knowledge Base Article
Internal Error: Sub-system: DCALC, File: /quartus/ddb/dcalc/dcalc_bcm_modules_cache.cpp, Line: 176
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 23.1, you may see this internal error when you compile a design with only the Intel® Cyclone® 10 GX device support installed.
This problem occurs because the tool uses the Intel® Arria® 10 timing corner during compilation.
Resolution
To workaround this problem, install the Intel® Arria® 10 device support in the Intel® Quartus® Prime Pro Edition Software.
This problem is scheduled to be fixed in a future release of the Intel® Quartus® Prime Pro Edition Software.
Updated 2 months ago
Version 2.0
