Knowledge Base Article
Internal Error: Sub-system: CPT, File: /quartus/sys/cpt/cptc/cpt_ampp.c, Line: 5800
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 23.2 and earlier, you might see this internal error when compiling a design using the Intel® FPGA IP Evaluation Mode.
Resolution
To workaround this problem, compile the design with a valid IP license in place.
This problem is fixed beginning with version 23.2 of the Intel® Quartus® Prime Pro Edition Software.
Updated 3 months ago
Version 2.0
