Knowledge Base Article
Internal Error: Sub-system: CDB_SGATE, File: /quartus/db/cdb_sgate/cdb_sgate_compatible_registers.cpp, Line: 437 m_oterm_2_set_id_map.find(iname_id) == m_oterm_2_set_id_map.end()
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 22.4, you might get this error when compiling your project during the synthesis stage.
Resolution
To work around this problem, perform either of these two options:
  • Add the following assignment to your .qsf file
set_global_assignment -name AUTO_PARALLEL_SYNTHESIS OFF
This problem is fixed beginning in version 23.1 of the Intel® Quartus® Prime Pro Edition Software.
Updated 8 days ago
Version 3.0
