Knowledge Base Article
Internal Error: Sub-system: CDB_ATOM, File: /quartus/db/cdb_atom/cdb_atom_sys.cpp, Line: 3572
Description
Due to a problem in the Quartus® Prime software version 15.1, you may see this internal error when you have the post map view netlist viewer and the chip planner open at the same time.
Resolution
To avoid this error, do not open the post map view netlist viewer and the chip planner at the same time.
This problem is scheduled to be fixed in a future release of the Quartus Prime software.
Updated 3 months ago
