Knowledge Base Article
Internal Error: Sub-system: BITASM, File:/quartus/pgm/bitasm/bitasm_common_dev.cpp, Line: 1426
Description
You may see this Internal Error when configuring an Intel® Stratix® 10 FPGA using Intel Quartus® Prime Pro Programmer due to a corrupt or incomplete installation of the Intel® Quartus® Prime Pro Edition Software.
A full transcript of the error is below.
die == DEV_DIE_TYPE_NULL
Stack Trace:
   0x217d4d:
BITASM_COMMON_DEV::get_uib_die_info 0x82d (pgm_bitasm)
   0x21a7df:
BITASM_COMMON_DEV::retry_to_get_die_info 0x5ff (pgm_bitasm)
   0x2cc258:
BITASM_FAMILY_VAR1::precheck_data_type 0x218 (pgm_bitasm)
   0x2bccb5:
BITASM_FAMILY_VAR1::generate_bitstream 0x3c5 (pgm_bitasm)
   0x2cf0ac:
BITASM_FAMILY_VAR1::run 0x11c (pgm_bitasm)
   0x2ebd03:
BITASM_MGR::create_bitstream 0x1083 (pgm_bitasm)
   0x2151ab:
PGMIO_FBGEN_PROXY::create_bitsteam 0x146b (pgm_pgmio)
    0xbb872:
PGMIO_F2P::create_bitstream 0x362 (pgm_pgmio)
    0x86c95:
PGM_CHAIN_ELEMENT::generate_bv_list 0x115 (pgm_pgmio)
    0x84553:
PGM_CHAIN_ELEMENT::create_chain_element 0x10b3 (pgm_pgmio)
    0x7dfc7:
PGME_PROGRAMMER::lookup_device 0x27 (pgm_pgme)
    0x6e91d:
PGMWQ_DEVICE_TREE::lookup_device 0x4d (pgm_pgmwq)
    0x54adf:
PGMWQ_DEVICE_TREE::create_chain_element 0x1cf (pgm_pgmwq)
    0x4695e:
PGMWQ_DEVICE_TREE::change_file_confirm 0xa7e (pgm_pgmwq)
    0x45d7e:
PGMWQ_DEVICE_TREE::change_file 0x38e (pgm_pgmwq)
    0x7773b:
PGMWQ_FRAME_WND::on_change_file_action 0x3b (pgm_pgmwq)
   0x1de4f6:
QMetaObject::activate 0x576 (Qt5Core)
    0xe0a2b:
QAbstractButton::clicked 0xab (Qt5Widgets)
    0xe094c:
QAbstractButton::click 0x19c (Qt5Widgets)
    0xe177b:
QAbstractButton::mouseReleaseEvent 0x8b (Qt5Widgets)
    0x39f4b:
QWidget::event 0xdb (Qt5Widgets)
    0x185ef:
QApplicationPrivate::notify_helper 0x13f (Qt5Widgets)
    0x161fc:
QApplication::notify 0x8dc (Qt5Widgets)
   0x1bedd8:
QCoreApplication::notifyInternal2 0xb8 (Qt5Core)
    0x19935:
QApplicationPrivate::sendMouseEvent 0x325 (Qt5Widgets)
    0x61e88:
QSizePolicy::QSizePolicy 0x2d18 (Qt5Widgets)
    0x5fbfd:
QSizePolicy::QSizePolicy 0xa8d (Qt5Widgets)
    0x185ef:
    0x17476:
QApplication::notify 0x1b56 (Qt5Widgets)
   0x1bedd8:
    0x4ce30:
QGuiApplicationPrivate::processMouseEvent 0x870 (Qt5Gui)
    0x3473a:
QWindowSystemInterface::sendWindowSystemEvents 0x9a (Qt5Gui)
   0x2088d4:
QEventDispatcherWin32::processEvents 0xd64 (Qt5Core)
     0xb85c:
CallWindowProcW 0x4dc (USER32)
     0xb1ee:
DispatchMessageW 0x1ae (USER32)
   0x2080a5:
QEventDispatcherWin32::processEvents 0x535 (Qt5Core)
    0x50208:
qt_plugin_query_metadata 0x1d18 (qwindows)
   0x1baca2:
QEventLoop::exec 0x1b2 (Qt5Core)
   0x1bda33:
QCoreApplication::exec 0x143 (Qt5Core)
     0x113b:
qgq_main 0x8b (qpro)
    0x149f8:
msg_main_thread 0x18 (CCL_MSG)
    0x1609e:
msg_thread_wrapper 0x6e (CCL_MSG)
    0x20fa0:
mem_thread_wrapper 0x70 (ccl_mem)
    0x13f7d:
msg_exe_main 0x20d (CCL_MSG)
     0x2163:
WinMain 0x153 (qpro)
     0x1772:
__scrt_common_main_seh 0x116 (qpro)
    0x137e3:
BaseThreadInitThunk 0x13 (KERNEL32)
    0x6cb80:
RtlUserThreadStart 0x20 (ntdll)
End-trace
Resolution
Reinstall the Intel® Quartus® Prime Pro Edition Software to avoid this error.
Updated 1 month ago
Version 2.0
