Knowledge Base Article
Internal Error: Sub-system: BAL, File: /quartus/synth/bal/bal_ec_balancer.cpp, Line: 1463
Description
Due to a problem in the Quartus® II software version 12.1 and later, you may see this error during Analysis & Synthesis when compiling designs with high RAM Block usage.
Resolution
To work around this problem, add the following assignment to the Quartus II Settings File (.qsf) file:
set_global_assignment -name AUTO_RAM_BLOCK_BALANCING OFF
Updated 24 days ago
Version 2.0
