Knowledge Base Article
Internal Error: Sub-system: ASMPLL, File: /quartus/comp/asmpll/asmpll_28nm.cpp, Line: 231
Description
Due to a problem in the Quartus® II software version 12.0, you may see this error if your HDL code implements a PLL in normal or source-synchronous mode and drives an external clock output. This problem affects designs targeting Stratix® V, Arria® V, and Cyclone® V devices.
Resolution
To work around this problem, do not use normal or source-synchronous mode and an external clock output at the same time.
The issue is fixed beginning with the Quartus II software version 12.0 SP1.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
