Knowledge Base Article
Internal Error: Sub-system: ASMIO, File: /quartus/comp/asmio/asmio_reg.cpp, Line: 6596
Description
If you apply the set_max_skew Synopsys Design Constraints (SDC) constraint to a DQSn pin in a MAX® 10 design that includes the LPDDR2 EMIF IP, the Quartus® Prime Standard Edition software\'s Assembler encounters an internal error.
This issue affects MAX 10 designs that target the 10M16, 10M25, or 10M50 devices.
Updated 2 months ago
Version 2.0
