Knowledge Base Article
Internal Error: Sub-system: ASM, File: /quartus/comp/asm/asm_split_bits_utility.cpp, Line: 612
Description
Due to a problem in the Quartus® II Software version 13.0 SP1 and earlier, you may see this error when compiling a design using the Partial Reconfiguration (PR) or Configuration via Protocol (CvP) features. The problem occurs if the SignalTap™ II Logic Analyzer is used in the static portion of the design and the static region placement is being preserved using a top level persona file.
Resolution
To avoid this error, remove the SignalTap II Logic Analyzer from the static portion of the design.
This problem is scheduled to be fixed in a future release of the Quartus II software.
Updated 2 months ago
Version 2.0
