Knowledge Base Article
Internal Error: Sub-system: ASM, File: /quartus/comp/asm/asm_lab.cpp, Line: 8102
Description
Due to a problem in the Quartus® II software version 12.0 SP2, you may see this internal error if the pin_perst port of your PCIe block is not connected to an nPERST pin.
Resolution
To work around this issue, connect the pin_perst port to the nPERST pin or follow the process defined in the related solution below.
Related Articles
Updated 1 month ago
