Knowledge Base Article
Internal Error: Sub-system: AMM, File: /quartus/db/amm/amm_atom_mod_util_impl.cpp, Line: 2108incompatible partitions
Description
Due to a problem in the Intel® Quartus® Prime Software Standard Edition version 15.1, you might see this internal error when you compile an Intel® Arria® 10 FPGA design that contains transceivers and has Spectra-Q Physical Synthesis enabled.
Resolution
To work around this problem, either disable the Spectra-Q Physical Synthesis or install the Intel Quartus Prime Software version 15.1 Update 1.
This problem has been fixed in the Intel Quartus Prime Software 17.0.
Updated 2 months ago
